Bryan James
30 points
Posted on - 10/05/2012
Hello experts,
I need to download touch pro 2 driver for XP. If there are no drivers attached to a system it would probably not work or run and I want it for my windows XP.
I hope you can give me a secure website to download it for free since I don't want to risk the safety of my system.
Thank you.
I need to download touch pro 2 driver for xp.
Hello! Good Day!
May I know what is the model name/number of your touch pro? It would be hard to search for its driver if you don't know its model name/number.
If you don't want to take risk on downloading its driver on the web, one alternative solution is to restore its driver.
How to restore a driver in XP:
1. Click Start > Control Panel > Performance and Maintenance > System. Select the Hardware tab. Click Device Manager.
2. Look for the device that isn't functioning. In your case look for the Touch pad. Then Right Click and select Properties.
3. Click the Driver tab. Select Roll Back Driver. Then restart your computer.
Also, if none of the solution works, try system restore. Choose a restore point where your touch pad was still working.
Hope this helps!
Touch Pro 2 is a software that comes with HTC mobile devices. I think you just need to go to your provider's website and search for the driver or updates.
Say you are under Sprint, just go to their official site and click on the software update.
Or If you are under Verizon, just do the same steps to download the update on your Windows XP PC.
After you downloaded the driver, connect your HTC device to your PC and follow the on-screen instructions.
Hi Dear,
There are a lot of websites that provide free drivers to download.
You can download any driver in just a few minutes.
I am going to suggest a website to you that will provide better drivers.
You should visit this website.
Search your device’s model on this site to find drivers.
