I just added another PC at home, and I'd like to install my printer but I could not find the driver for it.
I have Core i5 processor and Windows 8 64 bit.
My printer is HP Photosmart k510a with ePrint.
Does someone have the driver pack for printer k510a?
I need driver pack for printer HP
Hi.
You can download any driver from the HP site.
All you have to do is to follow these steps:
1. Go to this site
2. From the top menu click 'Support and Drivers'.
3. In the middle of the page you have also Support and Drivers – click it.
4. In the search box type your product name (if you don't find it – type product number).
5. You will be redirected to a page where you can select the OS and below you can start downloading the driver for your printer.
If you don't find the product in the search results from step 4 just go on this link and select your Operating System:
You can download the HP Photosmart Full Feature Software and Drivers from HP website.
In case you are finding it difficult to download, follow these steps:-
2. Select your operating system from the list given there.
3. Click on Driver – Product Installation Software.
4. Now you may download HP Photosmart Full features Software and Drivers OR Print driver without Photosmart software suite.
Laz Zebbena
