I need drivers of Belkin N300 for Windows 7
Dear Experts,
I formatted my PC and lost drivers of Belkin N300 wireless router. Please share the link to download Belkin Drivers Utility of N300 Wireless Router for Windows 7. I cannot use the internet due to this problem.
Answered By 0 points N/A #152105
No worries, because you can still set up your wireless internet connection even though you have lost the CD driver. You can set it up manually instead. Here's how
Initially, reset your router to its original or default setting. Turn router power ON. Insert a pin into the reset hole found at the back of the router. Push and hold for about 10 seconds. You will notice that the lights on the front would start blinking. Unplug the router power when the lights stop blinking for about 30 seconds. The router has been reset.
Plug the power into the router again. Grab the Ethernet cable and plug it into one of the router’s ports (Port 1, 2, 3 and 4), and plug the other one into your computer. Now open a browser, then type 192.168.32.1 at the address bar and hit “Enter”. If the 192.168.32.1 doesn’t work try 192.168.1.1 or 192.168.0.1.
When username and password tab popped out; leave both username and password blank press “Enter”. If that doesn’t work try (Username: Admin, Password:Blank). Usually the router default username and password are written on the sticker label. Look for the bar which says the wireless network name or SSID. You want to enter a name which would serve as the username of your wireless network, lastly assigned a password on the WEP bar.
Belkin router IP address Wireless ADSL Modem Router
