I need drop shadow photo software
Hi, I’m applying for a part time job at photography magazine, I received a bunch of images and I’m asked to redesign them by adding some simple effects like adding glow, dropping shadow and color enhancing etc. I tried the simplest way to do that and I found some websites where I can easily upload photos and select the effects I like and get the output, now I’m looking for a drop shadow photo software for a fast results and simple steps.
Answered By 0 points N/A #174041
Hi Any Hill,
If you are interested in photo editing or photography and you want to excel with that, I would love to recommend you to use the Adobe Photoshop, it is a photo editing tool that you can do several task, like your request drop shadow, it is just a few clicks away. Now, if you want just a simple edit for the picture, you can use the simple Microsoft Word, open it and import the picture and right click the picture and add effects, add shadows and that's it.
