What version of sequence diagram editor that could handle big size of data and can edit drawings and diagrams easily without consuming a lot of memory in my pc? I have a big file size of sequence diagram from a job portal.
I need an editor of sequence diagram from job portal.
Hi dear,
I think you need to use quick sequence diagram editor 3.1.
It is very fast and easy to use tool. It is a tool from we can create UML sequence diagrams just using textual descriptions of objects.
It can handle big size of data.
It is a tool which automatically lays out lifelines and messages, don’t need to drag the objects into the canvas.
You can get this software from here.
Hope this will help you
