I need feedback on Skype screenshots format
Hi guys.  I'm trying to take screenshots using Skype.  Where does Skype save the image file and in what format?  I need feedback on the Skype screenshots format.  I'm on a Windows XP 64 bit system.  Thanks in advance.
Answered By 80 points N/A #143140
Greeting Gwendolyhunterr,
I never heard of Skype being able to take screenshots and I'm using it for many years. As a matter of fact the way to take screenshots is usually in Windows function itself. In order to take a screenshot do the following
1. Press the Print Screen key on your keyboard (Prt Scr on some keyboards). This will copy the current screen in your keyboard.
2. Open some image editing program. The easiest solution is Microsoft Paint. Once it's opened go to Edit -> Paste or press CTRL + V on your keyboard. The image will be pasted into the work area.
3. Save the image in the desired format with desired name on desired place.
You can also check this link here on the official Skype website: Skype screenshot.
Hope I have helped you,
