I need the files to play as autoplay on rollover
Hello expert, I need to link rollover to launch quick time player. Also I need the files to play as autoplay on rollover. How can I perform this rollover autoplay menu on my quicktime player?
I think what you are talking about is a playlist. It's not called "rollover". It's way easier to use iTunes to create playlists. But you can create playlists in QuickTime Player, too. Here's how:
You first start the QuickTime Player, then click "File", select "Open". Choose the media files (choose multiple files by pressing Ctrl or Shift) you want to add to the playlist. Then click "File" and select "export" option. Then click "Movie to QuickTime media" link. Follow the instructions then. Eventually you will save a file in a specific location. The file bears ".qtl" extension. It's the QuickTime playlist.
