I need to find and download antivirus with alert sound
I am an instructor at the private university. I need an antivirus software that gives a loud alarm sound when something occurs. Then I can easily identify when something happens when student using the computers.
Thank you.
Best Answer by Musick Adam
Answered By 5 points N/A #149332
Hi!
You can use Avira AntiVirus. There are settings where you can customize it so that when a virus appears you can be alerted.
First, open Avira. Click "Configuration."
In the next window, click "General" under the Expert mode.
In the drop-down options, choose "Acoustic Alerts" and you can use WAV sounds.  Just choose “use the following WAV-file”, and you can pick the alert sound you want to use. Then click "OK".
 Enjoy!
Answered By 0 points N/A #149333
Hi Mackenzie!
Regarding your inquiry about an anti virus software that has a loud alarm sound in case something is wrong, I would recommend that you should use Zone Alarm. This is an anti-virus which offers a multi-layered protection for consumers against identified and new threats especially nowadays. It is a combination of anti-virus plus firewall which will enable to protect the entire system of your laptop or PC from intruders,viruses,spyware and other malware.
It will make a noise once a threat has been detected. The firewall is the same as that of what has Zone Alarm has produced for years however with basic antivirus and anti-malware tools included. And oh, you can download it for free, Just visit for Zone Alarm and you can already download it exclusively from this site.
Hope this will work for you.
