I need to find Sourceforge Converter , please help
Hi All
I am a Mac user. Want to convert M2TS Video to AVI.
I have heard about Sourceforge but couldn’t find.
Can this converter convert M2ts video to avi or mpeg?
If yes please help me find sourceforge m2ts converter.
Answered By 5 points N/A #167957
From SourceForge you can download MP4Cam2AVI Easy Converter. It’s very fast application and have a great reviews. This is the downloading link: https://sourceforge.net/projects/mp4cam2avi/
Alternative, if you want to use another one, on the link below you can download Video Converter for Mac OS. You can convert your video files from M2TS to AVI and you have some editing features.
This is downloading link: http://download.iskysoft.com/cbs_down/video-converter-intel_full139.dmg When the download and install is finished, lunch the Video Converter, add M2TS files by drag and drop in AVI MAC app.
Then from file menu, select Load Media Files and select the M2TS files that you want. Now from output format list select the AVI and finally click at Convert button.
Williamson Mellisa
