I have this broken iso file. I've been having a hard time opening it. I can't even open my file using nero. How can I troubleshoot this problem? If simply fixing it on my own won't work, are there any program that can be used as fix for bad iso file? Free downloadable programs are very much preferred.
I need a fix for bad iso file
Hi Darreno Marcy. First, try to check your software if it works properly. Uninstall the software then install it again. If it doesn’t work, upgrade your ISO file. If there’s still a problem after upgrading, download Daemon Tool. Simply type Daemon Tool on your browser and look for the free downloadable version. Because the Daemon Tool would surely help. I hope this information will be beneficial with regards to your query.
