Hi guys. Can someone suggest a flash game fla code or script that I could use? I'm trying to make my first flash game. Can I also make modifications in an existing flash game template? I have Adobe Flash Professional CS6. Thanks in advance.
I need Flash game fla code or script
Yes, you can make modifications to existing templates but they will be required to be in the necessary file system so you can use it in Adobe Flash Professional CS6. Otherwise the conversion might not be as straightforward as expected.
In any way, it’s not a bad idea to have some scripts that you can examine and modify in order to learn and get some new ideas for a game.
