I need the free pc power speed uninstall from my computer
Hello, I installed the fake PC Power Speed. Now, I’m experiencing trouble with this software. I need to uninstall it. What is the proper way to uninstall it completely from my PC? Can you give me step by step procedure? I need this free pc power speed uninstall from my computer. Thanks a lot.
Best Answer by roya marsh
Answered By 0 points N/A #168513
Which version of windows are you using? I’ll explain the procedure step by step.
1.   Go to My computer and find a link to Add/Remove Programs.
2.   Click on the link and you find a window having a list if programs currently installed in the computer.
3.   Select the software you want to uninstall and follow the next steps to uninstall.
Answered By 0 points N/A #168514
The procedure is very simple and clear.
On the Start Menu click on Control panel and a dialog shows up.
Click on uninstall Programs and on the list select the PC power speed software, right click and select uninstall. It is as easy as that.
