I need a free PDF html converter please
Hello techyv.com!
I have here a Windows 7 laptop, and I have like so many MS word files on it. Most of them were case studies that we've made when we're in college. Now I want those case studies to be converted into a pdf file for my website, Please give me a link if there's any about a free pdf html converter. Thanks! something that is compatible in my Windows 7 32-bit laptop.
Best Answer by Johnny Mrmarshall
Answered By 0 points N/A #143902
Hello John Herring,
There are many PDF to HTML converter applications for Windows 7, which help you convert all of your PDF files to HTML format.I like the Some PDF Converter the best. It is very easy to use, and it is completely free.
You can convert multiple PDF files at a time. It is supported on a Windows 7 laptop.
Download this PDF to HTML converter here.
Now, enjoy it. Thanks.
Answered By 40 points N/A #143903
There are two ways to convert your desired pdf files.
Firstly, you can make the conversion through online using the free online converter link .
Secondly, you can make the conversion through offline by downloading the converter software using  pdf to html converter  2.1.2.24 .
Finally,above mentioned links are likely to clarify your queries.
