I need to convert WMA files to MP3. Is there a free tool that I can use to change the WMA files to MP3? If there is one, is it able to manage variable bit rate, batch jobs, high quality output and tags?
Sahibjot
I need a free tool for converting WMA files to MP3
 HI
I know what you need.You can convert any audio files to mp3 with only one software.
That is 'Goldwave'.
You can download it from
http://www.goldwave.com/release.php.
You can make changes to file types and bit rates.
Sahibjot
 To convert wma files to mp3,you can use one tool.
i would recommend you to use 'Goldwave' to convert your WMA files to mp3.
You will have the best options to convert your files from any file type to mp3.You can easily download it from
It has more features like audio recording,voice mixing,enhancing volume,effects,file splitters,file merger,cue points,real time visuals etc.
OR
You can go for 'audio converter'.
Another high-quality software which is easy to use and provide portable files which can be played on any device.
You can download it from here
https://free-audio-converter.en.softonic.com/
Both of the softwares are good.You will get additional features in both these softwares.
Free WMA to MP3 Converter can convert Windows Media files to MP3 files which can be played in MP3 Players. All Windows Media formats (*.wma, *.wmv, *.asf) are supported. The program is a freeware and does not contain any form of malware, including but not limited to: spyware, viruses, Trojans and backdoors.
Read more: Free WMA to MP3 Converter
It's clean and free, without any Adware or spyware. It's stable and fast. Easy-to-use wizard-like user interface helps you setup converting process easily.
Thumbs Up Techyv!
Now i'm enjoying converting my music. I was able to get a free converter (Goldwave) thanks to all.I was really having a hard time searching for these. 100% clean?yes it is!. Sahibjot, thanks also for the other tool you suggested.
