I need free visual fox undelete command related software
I need free visual fox undelete command related software to restores deleted files. Moreover, I need it for those which were cleaned even from recycled bin. Do you know any? I need the most effective and the most reliable. Please give your examples!
Answered By 40 points N/A #167602
You can use Recuva:  http://www.piriform.com/recuva.
This application is free, and it is the best free application for recovering deleted files.  It supports all known file formats and it can recover files which were deleted long ago.  This application searches for sectors on your hard drive which contain some data, then it reads that data and shows it to you as image, sound, video etc.  I hope I helped.
Regards.
Answered By 590495 points N/A #327583
If you need to undelete or restore deleted files even when they are deleted from the Recycle Bin, try PC Tools. Try installing PC Tools Performance Toolkit. Once installed, start PC Tools then go to “Recovery” tab and click “Recover Lost Files”. Try selecting “Deep Scan” or “Physical Scan” in the “Scan type” option then select the drive you want to scan.
Click “Start Scan” to begin analyzing your hard drive. If the files you want to restore are located on the system drive originally or drive C, recovery is not guaranteed because continuous file activities are happening on the system drive. To successfully recover a deleted file, the drive where it is located must not have any “write” activity like copying or moving of files.
This is because the sectors the deleted file originally occupies can get overwritten with new data. Also, even if you managed to recover a deleted file, the content of the file is not guaranteed to be one hundred percent (100%) error free. Most of the time, the content is garbage.
