I need the FUJITSU Computer Drivers
Hi TechyV Friends!
I need help in finding the Fujitsu computer drivers for my desktop PC. I have a Fujitsu Esprimo D581 running on Windows XP Professional and I need to reformat my computer because the system was infected with the virus. My problem is that I do not have the complete drivers for my desktop. I think I have misplaced it and I need it immediately. Can anyone please tell me what is the next step after reformatting of my PC. What is the first essential driver that I need to download and install? What are the next steps? Please anyone I need guidance. I will be waiting for your responses.
Thank you very much!
Ammelia Jesse
Best Answer by Floyd A Beverly
Answered By 0 points N/A #149121
Fujitsu drivers are found on their website,http://www.fujitsu.com/fts/, you can download from the website>services and products on the dropdown menu>desktop PCs>D581, then select on your right you will see a link 'DrIvers and other downloads'. I would recommend that you install windows 7 as the OS because it is supposed to runon it. You have first have to download the drivers and save them on a media that you can install after formatting.
Answered By 20 points N/A #149122
Hi Ammelia Jesse
Good day
Hope you are fine. So your are going format your pc due to virus intervention, you should not need to worry about drivers because Fujistu support center has all the driver pack solution for all the models of desktop pc's. Here i am giving you a link, download all the desired drivers which cannot be installed automatically for particular for xp sp2. Mainly the drivers which can be installed auto on desktop pc while installing xp are audio and usb or may be network driver in rare cases. Hope this link will solve your problem.
http://www.fujitsu.com/hk/products/computing/index.html
Best Regards
Floyd
