I would like to know if there is an application specially made to draw neural networks. If none, then can you give me an advice what drawing application is good to make neural network easily. If so, where can I download this neural network draw application? I am using Windows 7. Thanks.
I need a good neural network draw application
I have been using Microsoft’s Visio for years now and I love how powerful it is for creating networks and schematics. I definitely would recommend this! It’s just so easy to use with all the ready-made stencils and templates, all pre-drawn you just have to “drag and drop” it. Navigation is quite easy too. Interface is similar to Microsoft Word and the graphical interface is clean and simple. All of these features come with a price, Visio 2010 costs around 1000USD.
Here's the template page of Visio 2010.
If you find the price steep, here’s an open source drawing tool for your neutral network: Graphviz. It allows you to create structural diagrams and networks. Applications include bioinformatics, software engineering, web designs and visuals for technical applications. It may not be as powerful as Visio 2010 but it is good enough to develop neutral network sketch.
Taylor
