Lisa Larsen
Posted on - 04/29/2013
I just purchased a new Sony BD – enabled notebook and I am a movie fan and I love to collect high – definition movies and video contents on my PC.
I am curious if I can use the inter video blu ray free software and incorporate it with the built – in BD Software on my PC?
If so, can I store my movies to any Blu – ray disc?
Does this include AACS content protection as well?
Just want to make sure that my movies are protected.
I need help about the intervideo blu ray free software
Hello Lisa Larsen,
As you are fond of movies so if you want to integrate the inter video Blu ray software with the built in Software then that is ok.
As windows provide you the facility that either you can use the internal one or you can use any other that you want to use.
After that you can store that movie in any of the Blu ray disk that will remain well protected at all.
It can give you any type of protection that you want to get but you have to set the priorities by yourself.
