I need help in Aha Soft Articons
I just installed Aha Soft Articons Pro so I can create and edit icons on my Windows XP 64 bit system. How do I split icon libraries into a single icon file? Any help would be much appreciated. Thank you.
Hi Elsietbrown,
You didn’t mention which Aha Soft Articons Pro version you installed. Because many of the Aha Soft Articons Pro version doesn’t support on Windows XP 64 bit system. You can use Aha Soft Articons Pro 5.42 version which supports on Windows Vista, XP, 7, 64 bit system.
You can easily split icon libraries into a single icon file by the below steps.
1. Open Articons pro tools.
2. Then select New Library from file menu. Then new icon library 1 tab sheet is opened.
3. Open all libraries which you want to want to split.
4. Then copy icons that you want to add new icon library 1 tab sheet by drag-drop.
5. Now save the new icon library 1.
It’s okay. Your task has been completed.
I hope that it will help you.
Thanks
Taylor Delapena
Notifications
