I need help with AirPrint activator Mountain Lion. My iMac with OSx Mountain Lion could not detect my printer. I have the HP K510 PhotoSmart all in one printer with ePrint capability. Any help would be much appreciated. Thanks in advance.
Greetings,
The first thing you need to check is the printer itself. Does it work when directly connected to your iMac? Have you done a self test? Assuming the answer is yes, the next step is to make sure that the printer is shared. Go to Preferences, then Print & Scan and tick "Share this printer on the network". Launch AirPrint Activator and toggle the "on" switch. It should now be able to detect your printer.
In some cases, AirPrint Activator does not work 100% of the time.
