I need help with Android RTC system
20 points
Posted on - 05/06/2013
Hi. I have the 32 GB Samsung Galaxy SII that has the Exynos chipset, Dual-core 1.2 GHz Cortex-A9 CPU and Android OS Jelly Bean. Is there a way to create an Android RTC system where the alarm can still trigger even when the phone is turned off?
