Hi guys. I'm having trouble with this mail bot. It keeps on sending me spam messages on MSN and Hotmail which is very annoying. I need help with bots MSN email remove permanently. Would an antivirus detect this problem? Any help would be much appreciated. Thanks in advance.
There are two things you can do. Use this software Spam Gourmet which is a spam blocking tool in order to protect your email from getting further spam. Next, before deleting spam emails, do email them to this government email address, spam@uce.gov and they will track down the sender and fine him.
Hi!
There are two ways that you may do to block all spam these steps
* Adjust the privacy of your account
* Block all email address that you don't want to message you so they again your any message to you
In adjusting the privacy of your account you need to follow these steps:
1. Launch the Windows Live Messenger 2011 (if that is your version) then log-in
2. Go to TOOLS in menu bar then select OPTION
3. Select the PRIVACY located in the left column then select the EDIT SETTING. Your default browser will appears then it will display the Windows Live privacy setting. Launch you can edit your account privacy settings you need to enter again your email address and password.
4. Select the ADVANCED link
5. Go to the bottom of the page by scrolling down your mouse lower the slider of the PRIVATE MESSAGES to FRIENDS. This will prevent anyone from sending any messages except for your friends in your list
6. You need to lower the slider of the FRIENDS AND GROUP INVITATIONS to FRIENDS or to MY FRIENDS AND THEIR FRIENDS to prevent those spammers on adding you to their friend list.
7. Hit the SAVE button to save all the changes you made
In blocking all the email address you need to follow these steps:
1. Go to MY MSN
2. Go to MY CONTACTS
3. Select OPTION
4. Select EMAIL tab
5. Select the PROTECTION AGAINST SPAM
6. Then select the RED LIST
7. Type all the email address that you want to block
Email bots are not malware on your PC so you cannot treat them like virus on your computer. Mail bots are programs that have found a way to retrieve your email password and are trying to take over your account. The best ways to get rid of mail bots and prevent them from getting access into your account are avoiding the use of the same email password with your other accounts, using very strong alphanumeric passwords with special characters and changing of passwords from time to time. Also, using a good antivirus that will get rid of any malware that are of keyword-logger types can help greatly in avoiding and removing email bots permanently.
