I need help for cache converter txt para PDF.
Hi guys,
I need a Cache Converter to PDF. Can you help me by suggesting solutions or programs for cache converter txt para PDF.
Thanks a lot for helping out.
Hi guys,
You can use many online converters that will help you to convert your .txt file to .pdf file.
Here is link:https://www.sodapdf.com/txt-to-pdf/
Just browse your .txt file and click on Convert and Download button. Or if you want you may download Text to PDF Converter such as
 http://download.cnet.com/Some-Text-to-PDF-Converter/3000-2079_4-10836745.html
Or you can convert your text file from Word to PDF. Download Virtual PDF Printer from here:
http://www.go2pdf.com/download.html
And install it. Then go to Control Panel and in Classic View double click on Printers. Set the Virtual PDF Printer as default printer. Now open your text file in word. On a file menu go to Print and select Virtual PDF Printer. Then click Print. A dialog box will ask you where to save the PDF file and click OK.
Williamson Mellisa
