I have about a dozen PDF files and I want to batch edit the color of the background. Do I need a third party application for color correction in PDF file or is there an option for this? I have Adobe Acrobat 9.1. Thanks in advance.
I need help in color correction in PDF file
Greetings Jeannej Grant!
You don't need third party application to change the background color of PDF files. Here is the step-by-step instruction on how to change the background color of PDF without third party application.
1. Open Adobe Reader and then go to Edit > Preferences > Accessibility.
2. Make sure that the "Replace document colors" is check and pick your preferred color.
3. Click "Page Background" color and select color of your choice.
But if you want some complicated task such as deleting text, change the PDF font color to gray scale and other related activities you want. You can download this PDF Editor and start editing your PDF's. I hope this will help you about your problem. Have a nice day.
