Hi fellow members,
I'm new to SharePoint Designer so please be patient with me. I'm trying to create a web page using SharePoint Designer 2007 in an LDAP server. Can someone here share a SharePoint designer LDAP template?
Thanks in advance.
I need help in creating Sharepoint designer ldap web page
To build a web page you have to add web parts, they are also referred as widgets, a good example of such is (ASP.NET) a framework developed by Microsoft. They assist you to specify or even modify the appearance and how your page behaves. From your website go to the menu bar and choose “create option” choose the web part page link, select format command and click OK. Enter the name of the page, choose a layout template and location save the page.
The next step is where we add the web parts, click on add web part option, from the dialog box that opens, select web parts, click on the open tool tab, scroll to the right side chooses the source editor. You can either copy and paste the link or type it and click on the exit mode option to complete the process.
