emileekeila
Posted on - 05/20/2013
Hello Techyv members.Â
I'm not much of a technical person so please bear with me.Â
How do I capture an IP surveillance camera MJPG stream using Delphi 2010?Â
Can someone here help me with Delphi MJPG stream?Â
Any help would be much appreciated.Â
Thanks in advance.
I need help with Delphi mjpg stream
Hello Emile
In order for you to be able to capture a stream using Delphi, you need a software related to this that is compatible with Delphi. It is called Dspack, it captures 12 images/second and it adds GPS coordinates to the image saving it as a picture on your computer.
You can download this software from the link I have provided you with.
After the install is done you will be able to use Delphi and capture with it.
DSPack Download
I hope you will find this information useful.
Randolph
