I need help fixing a problem with minecraft?
Well, actually the drivers have failed to identify the video drivers and minecraft couldn't startup. It also shows that there is a need for Advanced OpenGL in acceleration mode.
Can anyone help?
Can anyone help?
Yes your computer does not seem to be able to find any available hardware. A such the hardware in the system has to be installed. Do the following
1.      The driver must be avail able at the internet for download. Search the net for available driver for the device you are using.
2.      Install the driver found. If it is auto detected ten Ok. Else you need to Open device manager from Control Panel à Administrator tools à System à Device Manager. Here you shall find the VGA that is under Question signed. You need to reinstall the driver.
3.      If all fails then you need to find the provider of your device and then get the driver software from him. Then Install it with the previous steps.
