Hi guys. I'm trying to delete my internet history on my PC? I use Google with Mozilla Firefox. My Mozilla Firefox updated from 20.0.1 to 21.0. I used to click the tools menu then options then clear recent history. I now can't see that option in the tools menu. I need help with Google clear history PC.
Hi Dorethadhoward
Try to click on "Mozilla" top left of your screen. There should be the option to clear the story.
You can also use a software like ccleaners available here
you can use it to clean the history of all your browser and even fix errors in your system It's easier and safer.
Thank you
points
Every browser has got the built in utility of deleting browser history. You can use it easily without accessing any option even without mouse!
Open your browser and press “Ctrl+Shift+Delete” buttons. Then, the browser history deleting prompt will open. There, delete histories as you wish.
This technique works on all browsers.
