I Need Help Installing ITunes Windows
I was about to buy a new iPhone this month but I thought, first I should try and download iTunes just to check out whether I can get used to it or not. I have never used iTunes before. I need help installing Itunes?
Answered By 0 points N/A #324164
iTunes will act as somewhat of a central hub in what is called the Apple Ecosystem. Getting iTunes is very easy in my opinion and all you need to do is follow some simple instructions.
Go to the Download iTunes page on your computer and click on Download Now. Click save the file on the screen. Open the file that you have just downloaded. Click run and follow the instructions on the download wizard. Follow the instructions in the wizard and you will be fine.
