I need help in LAN gaming shop setup
Hi guys.  I plan on opening a gaming internet cafe.  I have about 10 PC's with Windows OS 8 and a DSL connection.  What kind of router should I buy for my setup?  I need suggestions in LAN gaming shop setup.  Please help.  Thanks.
Best Answer by Grimes Pal
Answered By 0 points N/A #131042
If you plan on opening an internet and gaming cafe, You need a reliable router with good quality.
I know some good router brands that has great user reviews all over the web that can testify how good of a router they are and if they are of the best quality.
A few samples are Cisco and Linksys. These brands are the most recommended brands of router I know.
Cisco has a great quality of service as well as Linksys and both are easy to install and setup.
When looking for the best router, The first subject you have to consider looking at is the Quality of Service (QOS).
This is very important. Always ask or research about this in any brands before buying one.
Answered By 0 points N/A #131043
I would suggest to go with a professional setup and get the Netgear ProSafe GS716T-200 which has 16 ports.
This is a professional switch and will certainly deliver you the highest QoS once set up correctly.
It is priced around 200 $
I suggest you go for this model and based on your need 16 ports will be more than enough for your network.
With 10 PC the load expected will not be high so this model will definitely fulfill your needs.
Cheers,
Frazier
