I need help. I accidentally deleted shared files on a network and I could not find them in the Recycle Bin. I just installed Undelete LAN recovery files software but I could not also locate the deleted files on the new Recycle Bin. Can someone please help me recover the files. I'm on Windows Vista 64 bit.
I need help with LAN recovery files software
Hi Donna, A Windows server plays the role of a file manager for your network users. Users save files to the server, and your backup process backs them it up. Just in case the user mistakenly erases files on your network server, shadow copies are utilized to recover backups. Shadow copies enable you to return a file to a previous version, allowing you to roll back any inaccuracy made to the file contents. Shadow copies also permit you to recover accidentally deleted files on the network. Hope this helps.
