lynn whine
Posted on - 11/11/2011
I have a Lotus Domino that is successfully running in our company and I want to upload some documents. The simplest way I can find is to have template of the Lotus Notes document library. Does anyone have any comments on Domino Wiki, DocPublisher or Doclibrary? I could explain this database to an intranet portal. Are there solutions which are ready to use for Lotus or is it easier to use WordPress or Drupal?Â
I need help with Lotus
Hi Lynn Whine,
    I do not recommend you to use Lotus Domino for managing of your documents.  Because it looks buggy even after you've done many patches on the document.  What I recommend you to use is the WordPress or Drupal.  Because it is more easy to use. working with wordpress is really impressing.  Try using a Dokuwiki it will also help and guide you on some information and technology.
   I think whatever you do if you make it simple and informative it will always be good help and relevant to others.
Hope this might help you.
Thanks
Shond
You had asked for solutions that how you could be capable to upload some documents in Lotus Domino that should be done with Lotus Notes document library or with DocPublisher or with Doclibrary.You can use any one of Lotus Notes document library,DocPublisher or Doclibrary.Which one that Lotus Notes document library can be more usable to create and save your valuable documents.Various software has various options.So that you shouldn't use wordpress or Drupal with Lotus.We should to know now which software had been related to Lotus.Generally encrypted data has shown in the Lotus.
