I just created a metallic background using Adobe Photoshop on my Windows XP 64 bit desktop. How do I put it on my iMac so I could also use it as the background? I have the 21.5" iMac that has the 512 MB Nvidia GeForce GT 640M Graphics card and OSx Mountain Lion. I need help with Mac metallic background. Thanks.
Hi Dorothy. If you want to transfer your created Photoshop file, do it in your wallpaper on your iMac. First for your information iMac is not accepting any files that were created by Microsoft windows. You will need to convert your windows file so that it will be accepted by your iMac. This is how it works, first you need to make sure that your Photoshop file is in JPEG format. After that you can put your file in your iMac then you need to have Automator application. You can search any site for the Automator tutorial. I've found out that you can do another user and share it to the other user admin privileges. Log in it into Adobe software and look if you can diminish it. I hope this helps.
