Hello there. I already have the Modal Box plug in installed. How do I create a basic light box effect in Joomla 1.5? Can someone help with modal box Joomla how to use tips? Any help would be much appreciated. Thanks in advance.
I need help with Modal box Joomla how to use tips
Since you have already installed your preferred modal popup dialog box plugin, what you need to create now is the CSS3 effect for the plugin, this would only be a css modifications and no javascripts that could hurt your joomla 1.5 website.
I suggest you follow this link below so hava an insight of what you prefer to have as a design for your modal box. Also, through the linked website, you can see several demos and sample lightbox effects and you will be provided with a source code download link used by the demo pages.
https://tympanus.net/codrops/2011/12/26/css3-lightbox/
