I need help in Msdos SSH command
Hi.  I'm new to SSH and I would like to have complete control of my system and applications.  Is there an msdos SSH command for what I want?  I'm on Windows XP 64 bit Sp 2.  Any suggestions would be highly appreciated.  Thanks.
Best Answer by Sharath Reddy
Answered By 0 points N/A #172929
Hi!
I recommend PuTTy, it is a Telnet and SSH client. You need to download it and I think its a freeware.
I do hope my comment would help.
Regards!
Answered By 590495 points N/A #172930
SSH refers to Secure Shell. It is a cryptographic network protocol intended for protected data communication, remote command execution, remote or distant command-line login, and other secure network services among 2 networked computers that are connected through a protected channel across a vulnerable network, a client, and a server that are also running SSH server and SSH client programs.
Since you are looking for an SSH tool that can be used in a DOS command line, SSHDOS will be a good candidate. It is an open source SSH, SFTP, SCP, and telnet client for DOS environment. To use it, of course, you need to be well-rounded in different DOS commands because you will surely encounter problems navigating within DOS environment in case you are only a beginner.
To download SSHDOS, click SSHDOS Sockets Latest Version or visit SSHDOS Download Page for other files. For other information that may be handy to you, please visit SSHDOS Open-Source Client for DOS.
