I need help with my cam A140BV driver.
Hi Guys! I am running Windows 7 professional and I have been using my webcam without any problems. I have no idea what happened, but now I cannot use the webcam. It is a cam A140BV driver. There is always something showing at the notification area that drivers are being installed and then it always fails. How do I go about it?
Best Answer by Carroll Coury
Answered By 10 points N/A #130757
Hi James Rio Allen,
Maybe you don't install the driver of cam A140BV and instead use the Windows 7 & 8 plug and play features which supports many of new devices by downloading its driver through windows update. I suggest you download its driver or if you have the existing driver try to reinstall it. If the problem still persist, try to change the location of its USB port. I hope one of this solutions will work on your problem.
Jose D Dunn
Answered By 0 points N/A #130759
Greetings! James Rio Allen
Your web camera is Mentor A140BV sized by 640×480, has a CMOS sensor, 300K/VGA Primary Color, have lens sized 3.5mm F=2. 0, and a Frame rate of 30f/s at VGA. It supports only Windows ’95, Windows ‘98, Windows ME, Windows 2000, Windows XP of two versions (32-bit and 64-bit) and Windows Vista. The installers warned their clients that the drivers must be installed freshly after OS installation. I suggest to change your OS which is near to Windows 7 Professional (which is Windows Vista), or, change your web camera to suit Windows 7 Professional. Here’s the link for more information, in case you change your mind to change your OS: http://download.cnet.com/s/chat-voip-email-webcam-video/windows/
Answered By 40 points N/A #130758
Hi dear James Rio Allen,
Thank you for your question. As par my knowledge, you have to reinstall the webcam software.
Hopefully by this way you can overcome the problem.
If you still face the problem, then follow the following steps-
Download the driver from the following site and use the driver-
Driverguide Fast easy and comprehensive
You can use the following software for your webcam, use the state link-
Download.cnet Webcam Software
That's it.
Hopefully by this process you can bypass your problem
