Hello all! I finished uploading my new roster to my iPad just today. I have noticed that the rest period bar located at the top left of the radar screen has vanished. Have I deleted it accidentally? Or I just haven’t set something correctly? Is it possible that it would just disappear without me deleting it? Do you have any ideas how to retrieve it?
I need help on my iPad
If you installed the roster application on the ipad properly then the rest period bar should also be there. The problem as to why it is not showing could be because of the settings you have set for the application and therefore you will need to review them and change them.
Check if the problem is with how you have configured the roster settings and change them.
If you have set the application so that the rest period bar will be in the auto hide mode, then you will need to change the settings so that the bar is set to visible.
Another thing that you should try doing, just restart the ipad and see if the bar will be visible after the computer reboots, and also check if the application is listed among the installed programs.
Regards
Thompson Locker
