gnecor
Posted on - 10/31/2011
Hi Team ,
I really need your help on my iPhone, I want to lock it in landscape so it won’t keep on auto rotate and I don’t know on how to search notes in contacts.
I already tried to find help from Apple technicians, but nothing really helps.
Will you please help me?
Thanks
I need help with my iPhone Please
Hi Gnecor,
   There are TWO  WAYS on HOW TO DISABLE AUTO ROTATION for iPHONE
First you have to installed the iNO ROTATE application in your iPHONE. After installing there will be a new option in your settings called iNO ROTATE.  To remove the automatic rotation , just  turn on the ENABLE option. This application also offers not only for the completely removal of  all mode of automatic  rotation for all apps but also it  adds another option to let the applications remove selectively.
ILLUSTRATIONS BELOW SHOWS THE iNO ROTATE Â APPS
You can always configure the settings of iNO ROTATE, For example you want to read a web page, and if you want the auto rotate to be  back  and it's so easy.
     2.   You can also installed a plugin called Rotation Inhibitor which allows you to switch on and off  the automatic rotation  for the settings of your SB.  You will just hook the status bar to activate it.  Then using this app, clicking the button inhibitor will allows you remove the auto rotation or enable it again.
The illustration below is the sample plugin Rotation Inhibitor
Hope this might help you.
