I need help with Photoshop Brush Tool Plugin
Good Day Techyv Friends!
I need help with the Photoshop brush tool plugin. I am looking for the best brushes I can use with Adobe Photoshop  CS3. Can you suggest your best brush tools guys? Also, I would like to know if I can use the existing brushes from my old Photoshop 7? I know I just downloaded it somewhere but do you think it is possible to reuse them in CS3? Can anyone please guide me on how to reuse them in CS3? Your comments and suggestions will be much appreciated.
Thank you!
