Hi. Can someone lend me a PHP code to batch convert a lot of HTML files to PDF files? I need them in PDF file format to be printer friendly. I need help with PHP turn HTML files to PDF files. I'm on Windows XP 64 bit. Thanks.
Hi!
I recommend you to download the "HTML to PDF Converter" this software is free to download. This is very easy to use, you just need to enter the URL of your website then select "Convert to PDF" and this program do the rest. It will also allow you to make password to protect your file. You don't need to install this software to your Computer and you will download this as a zip file so all you need to do is extract this then open and you can now start converting all HTML files you want.
