I need help recovering deleted files (with shift-del)
When a file is deleted from your machine, the data isn't destroyed immediately. Windows simply marks the space in hard drive being available for use by changing one character in the table. As I know, you can download free recovery software as follows to recover deleted files.
Thanks for the useful information. I tried possibly all the software and they detected the files but when I tried to open it in Excel it gave me a message that "The Document is Corrupt and to repair it use the open and repair command in the open dialog box (file menu) and select extract data when prompted"
But I do not know where to do it. When I go to open it does not say open and repair. Does it mean that the recovered file can't be opened?
Let me know if this does the trick.
Thanks for the help! I was able to retrieve my Excel file.
One of the best that I already tried on recovering deleted files is the Recuva software.
It can help you recover files that are deleted from crashes, files that are deleted from the Recycle Bin, from the memory cards or MP3 players.
It also allows the user to undelete files on their computers, or even if you have a damaged disks.
It can restore your Word documents, recover your emails.
And most of all, this is a free software.
Notifications
