How do I extract an audio file on a DVD then convert it into wav file format? I have a 13" MacBook Pro with Intel Core i5 2.5 GHz, 8 GB RAM, Intel Graphics HD 4000 and OSx Snow Leopard? I need help in ripping DVD to wav Mac. Thanks.
There are many utility tool that you can use for converting your audio to WAV format. You can try the Switch Audio File Converter. This is a multi-format audio converter that is very easy to use. It can even extract your audio from your DVD video. It can also convert 40 audio file formats such as wav, mp3, ogg, mov, wmv and a lot more. You can get it free or purchase a license from the link below:
http://www.nch.com.au/switch/index.html
