Edwaard Lee
30 points
Posted on - 05/22/2013
Hi Techyv members. I need help with SQL builder for tsm files. I have already connected to a database and I am always being asked to re-authenticate with the database when I open a .tsm file. Anyone having the same problem? Thanks for looking.
Hello Edwaard,
These kind of problems are often encountered while using tsm files with SQL server.
The reason you are asked to re-authenticate with database every time you open a tsm file is because you have not registered TDP (Tivoli data Protection) for SQL on TSM server.
Before using tsm files with SQL server, you first need to complete this registration and the steps to complete this registration are available here.
Hope you find this useful.
