There are some websites that I am unable to access on my PC, but my friends can. I am getting access to this page is denied on a web browser, whether it is Google or Firefox. Please help.
I Need Help To Get Rid Of The Access To This Page Is Denied Message On A Web Browser.
There can be several reasons for getting access to this page is denied message on a web browser. I can help you with some fixes.
Method 1
If you use VPN, try this.
a. Right-click the Start menu button.
b. Click on Run.
c. Type ncpa. cpl and press enter.
d. Right-click your VPN.
e. Disable it.
f. Try to open your website.
Method 2
a. Open Chrome.
b. Type chrome://extensions/ and press enter.
c. Disable VPN extensions.
d. Restart Chrome.
e. Try to open your website.
Method 3
1. Open internet options by searching in the Windows search box.
2. Go to the Connections tab.
3. Click on LAN settings.
4. Uncheck the option that says, “Use a proxy server for your LAN option.”
5. Click, OK.
6. Open your browser, and run the website.
