Halton Roy
50 points
Posted on - 03/17/2013
Hi there. Â
I have appointments spread sheets that I have created in Microsoft Excel 2007. Â
Is there a way I could transfer them in GoogleDocs spreadsheets?Â
I'm using Mozilla Firefox if that matters.Â
Thanks in advance.
I need help in transferring appointments spread sheets
Hello Halton,
It is quite easy to transfer your Excel spreadsheets to Google Docs.
Say you have an Excel spreadsheet you want to edit with Google Docs.
Open Google Docs homepage, Click here to go there.
Login to account or create one if asked.
In Google Docs homepage click Upload button next to Create and choose Files…
3.
Browse to import to Google Docs.Â
4.
Start uploading documents, spreadsheets.Â
5.
Open uploaded documents.Â
6.
Almost all the Excel formulas and function would work in Google Docs as wellÂ
7.
Hope this helps you.
Thanks
