elin ortie
10 points
Posted on - 05/21/2013
Hi! I am searching for a base on which I can use on working with my project. I already have flash presentation template files. However, I would like to update these so that I can have better outputs. Where can I find free downloads of new flash presentation templates?
I need help on updating my flash presentation template files
Hi there Elin, How is your flash presentation doing? I hope the links I will attach become much more helpful:
www.flashmo.com/
freepdfdb.com/ppt/flash-corporate-presentation-templates
You might also want to consider Kingsoft Office applications as well as Vector Flash presentation to get the latest flash presentation templates for free. Feel free to compare and select the best template suitable for you.
Hello Ellen, Using a flash presentation template file is more convenient when making presentations, here with me are the links where you can download for free www.flashmo.com this templates will make your presentations professionally made. I also found out this free software in which you can create your presentations more appealing this is the same with Microsoft PowerPoint http://www.kingsoftstore.com/presentation-free.html
