I need help with UPS connection
Hello, Can you tell me a way to check the backup of my UPS during power failure? Is it only the beep sound that shows the power? Thank You for your help.
Hi, What you have to do is connect your backup battery UPS to you available wall outlet, after which you charge the battery for the time period which was required on the manual, then you connect your pc to the UPS, and you power up your machine, when your pc is on, you then pull out the connection from the wall out let, ie, the UPS, you should be able to take off your pc with the beeping of your UPS, which suggest that the power has failed. If this does not happen then your UPS, is not working properly.
Hope this helps.
Hi, firstly connect pc connection into UPS. don't plug laser printer connection it give separate then you charge your UPS 6-7 hours then after charging u do main switch off for checking backup if ups does not give backup then u should change UPS Battery.
hi,
It depending on your UPS brand. Normal UPS have 3 LEDs as green, Yellow and red. Green indicate Power on and working, Yellow indicate Charging and Red indicate Input power frailer. And mainly they supply continues pulse beep and critical level battery sound with high tempo sound. So Use your UPS manual and check your UPS battery time and power support. Just you can check by unplug your UPS input power. Try it
Notifications
