Jem Mandap
50 points
Posted on - 05/30/2012
Hello!
I need help viewing a Calendar I just made at https://www.office.com/.
Is it possible to view the Calendar in saying Google Chrome, Firefox or IE or any other browser?
Whenever I go to the link it redirects me to the outlook and tries to open the calendar there.
Your ideas are very much appreciated.
I need help viewing a Calendar I just made in Office.com
Jem whatsup, your query can be solved. What you need to do in this case to solve this issue is to open the calendar with a usual browser like internet explorer. The main reason that the browsers open the calendar with Ms Outlook is because it is the software usually most recommended to open the application.
You can disable all anti-virus in the computer also. The Ms Outlook software doesn't usually work in compatibility with the Firefox browser. It is therefore advisable to use the alternative browsers instead.
The calendar is usually more advisable only used in Ms Outlook. You may try restarting Firefox and it should work.
