I need help with virtualbox
I need help with Virtualbox. Already the Virtualbox-dkms package is installed. But sudo modprobe vboxdrv displayed that vboxdrv is NOT set up. Then I try to re-setup. But I got the same error.
After that I uninstalled as well as re-installed Virtualbox with all helpful packages.
However same error message came.
Virtual – Editor In scriptOSlnit
Kernal driver not installed (rc=-1908)
Please install the vertualbox-drms package and execute
'modprobe vboxdrv' as root.
                             Abort
Failed to open a session for the virtual machine WinXP.
The virtual machine 'WinXP' has terminated unexpectedly
during startup with code 1.
Details
Result Code :           NS_ERROR_FAILURE (0x80004005)
Component:             Machine
Interface:                IMachine {5eaa9319-62fc-4b0a-843c-0cb1940f8a91}
                            Copy       OK
Please help me with total steps to get it running on netrunner. Please.
Thanks a lot.
Answered By 15 points N/A #148105
I think that you are having a compatibility error, you have to check if the virtual box that you have downloaded and installed in your computer is compatible to your current operating system because if you have this problem even if how many times you are going to uninstall and reinstall the software still you will get the same problem. I suggest that you download it with the package of the compatible operating system that you need.
 Hope this will help you a lot.
