Donna Davis
20 points
Posted on - 04/25/2013
I would like to convert some of my 2D JPEG images to 3D images. What is a good image convert in 3D software that can use a single image to convert to 3D? Batch conversion would be a plus. Any suggestions would be much appreciated. Thank you.
I need an Image convert in 3D software
Sorry to disappoint you but I do not think it exists. In addition, the technology is not really the point. Indeed, the principle is somewhat the same as the now integrated standard on all Blu-ray HD 1080p up scaling. It is the final that an artificial inflation whose effectiveness depends on both the nature of the source of its intrinsic quality and computing power conversion circuit. . Otherwise, you can try with: http://www.photo-to-3d.com/ or http://www.3dsom.com/.
